npm ERR! fetch failed
https://registry.npmjs.org/infinite-tree/-/infinite-tree-1.15.0.tgz
npm WARN retry will retry, error on last attempt: Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
https://registry.npmjs.org/react-infinite-tree/-/react-infinite-tree-0.7.1.tgz
https://registry.npmjs.org/three/-/three-0.90.0.tgz
https://registry.npmjs.org/styled-components/-/styled-components-3.1.6.tgz
npm ERR! Linux 4.14.70-sunxi
npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "--unsafe-perm" "-g" "cncjs"
npm ERR! node v6.14.4
npm ERR! npm v3.10.10
npm ERR! code ENOTFOUND
npm ERR! errno ENOTFOUND
npm ERR! syscall getaddrinfo
npm ERR! network getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
npm ERR! network This is most likely not a problem with npm itself
npm ERR! network and is related to network connectivity.
npm ERR! network In most cases you are behind a proxy or have bad network settings.
npm ERR! network
npm ERR! network If you are behind a proxy, please make sure that the
npm ERR! network 'proxy' config is set properly. See: 'npm help config'
npm ERR! Please include the following file with any support request:
npm ERR! /home/cnc/npm-debug.log
